enforce-version
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
enforce-version [adoption|cluster] [full|major|minor|none|strict]
Parameters
adoption |
Verifies
firmware versions before adopting. This option is enabled by
default. |
cluster |
Verifies
firmware versions before clustering. This option is enabled by
default. |
full |
Allows adoption
or clustering when the first four octets of the firmware versions match (for
example 5.9.3.0) |
major |
Allows adoption
or clustering when the first two octets of the firmware versions match (for
example 5.9) |
minor |
Allows adoption
or clustering when the first three octets of the firmware versions match
(for example 5.9.3) |
none |
Allows adoption
or clustering between any firmware versions |
strict |
Allows adoption
or clustering only when firmware versions exactly match (for example
5.9.3.0-010D). This is the default setting for both ‘adoption‘ and ‘cluster‘
options. |
nx9500-6C8809(config-profile-test-nx5500)#enforce-version cluster full
nx9500-6C8809(config-profile-test-nx5500)#enforce-version adoption major
nx9500-6C8809(config-profile-test-nx5500)#show context
profile nx5500 test-nx5500
no autoinstall configuration
no autoinstall firmware
crypto ikev1 policy ikev1-default
isakmp-proposal default encryption aes-256 group 2 hash sha
interface pppoe1
use firewall-policy default
service pm sys-restart
router ospf
router bgp
dot1x system-auth-control
dot1x use aaa-policy OnBoarding
Related Commands
no |
Disables or reverts settings to their default |
